If you look at your old posts you could tell if there used to be an issue or not. What I found with V12 was that there would be a block starting with G00 (which tells Mach to use max rapid speed) then coordinates, the next line would also have X&Z coordinates but no prefix, so the machine would stay in the rapid feed mode. The second line after the G00 is usually G01 plus coordinates. At the end of this line there should be a 'F 5.0' or something similar to specify the required machining feed rate. It is this Feed Rate command that does not show up in these instances, therefore Mach stays in max rapid speed for the duration of the entire process.
This sure makes for short machining times but really *********ty results, broken cutters etc, since you cant machine at max rapid speed......
So anyone that is using Dolphin Lathe V12 be cautious about this - and make sure you COMPLAIN to them about the screwed up post processor. I tried all the post processors that were available - and they all do the same thing, they DO NOT change the feed rate. So maybe this is an issue with V12, I have no idea, but it seems to me that it should be controlled by the post processor.
Perhaps Hood can shed some light on this? Like I mentioned previously, Dolphin is now aware of this and it should be resolved soon - their post writer guy is on vacation or something...... I guess they don't have a backup programmer....
The V12 will now work with the V11 posts - at least on my machine, but they have been into my computer twice now and they have downloaded and installed several licence files, several new post processors and the like, so it is hard to tell what my machine is doing, at least it is workable for now. the only way to test it would be to install the V12 demo software and try it out to see where it would be different from the V11, and also verify that the V11 and maybe even the V10 posts might work. Rodney told me it would be ok to use an older post for the time being, so it should work for everyone, if the post produces proper code.
Pete
Pete
