Hood,
I got the replacement boards yesterday, but before I install them, I want to get Mach to get to the point where it'll bring the machine up to some extent.
I copied the mvoros.xml file to Mach3 directory. As it is now, when Mach opens nothing is set in any of the configurations. The old xml file is still in the xmlbackup folder. Should I delete what's in that folder?
Anyway, I'm sorry about the BOB file not showing good. Can you import a DWG (autocad) file? You see the dwg file is only about 500KB, the dxf one is almost 3MB.
Mike
