Hello Guest it is February 05, 2025, 02:47:20 AM
Author Topic: Trouble with limit/home config  (Read 8179 times)
Re: Trouble with limit/home config
« Reply #10 on: May 10, 2013, 01:58:51 PM »
One or the other, not sure which!  What version do you recommend??
« Reply #11 on: May 10, 2013, 02:08:49 PM »
I use 056 and 057 on my machines but on the machines with the ESS and USB SS I am using older plugins and I think Jeff said you need 062 if you used the latest ESS/SS plugins.
« Reply #12 on: May 10, 2013, 02:19:51 PM »
One would think something as fundamental as referencing would be made to work in all releases.  I am using 066...
« Reply #13 on: May 10, 2013, 02:45:31 PM »
You would think so.
Until you try with an earlier version we cant be sure that is your problem but I do know homing was an issue for me with one or other of these versions.
 Please let us know if going to an earlier version solves your issues.
« Reply #14 on: May 11, 2013, 09:02:25 PM »
Version 062 works as expected.  Guess I'll stick with that until I find something there that is broken and needed!
thanks for your help...
fyi...this is the second time I have posted this.  The first version seems to have disappeared!
« Reply #15 on: May 12, 2013, 04:07:59 AM »
Thanks for coming back, glad you got it sorted. I will try again to make my feelings known regards 066 being the lockdown.
