Hello Guest it is September 20, 2026, 06:04:51 PM
Author Topic: Newbie XBOX controller question (Macros)  (Read 7352 times)
« on: May 11, 2013, 04:03:23 PM »
hi out there.
Hope someone has some guidance on a small problem I am having.
Installed the Xbox controller and it works great with one exception. I have assigned two macros for the two buttons and when I push the buttons during operation.
I get a message in Mach3 indicating the macro has been run. But nothing actually happens.
The macros are VBscript Macros that I know work as I can run them in the editor and they work fine.
But Mach3 doesn't actually run them. I have copied them into every folder I can think of in case its a path issue. Still no go.
If I delete the macros Mach still says it ran the macro when I push the button.
I am lost. Any thoughts.
cheers and thanks
