Hello Guest it is July 04, 2026, 01:37:29 AM
Author Topic: Will Mach3 let me pass the edge of a job past a fixed welding torch  (Read 23717 times)
Re: Will Mach3 let me pass the edge of a job past a fixed welding torch
« Reply #10 on: June 06, 2013, 02:22:05 PM »
Hi Stirling, thanks for your reply. Yes your right on the money!
The first video you posted is exactly what I got just using X,Y for a square, with a rectangle I got a parallel line inside the "D"
I have the Z A rotations enabled and the tool path rotates on the screen.
I will try to attach toolpath pic yet again.
Ricky
« Reply #11 on: June 06, 2013, 02:30:45 PM »
Toolpath shown about half way round the first corner.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: June 08, 2013, 04:43:04 AM »
Ricky - I think your code is the problem. Try this... not sure I got a couple of the arcs exactly right but you get the idea.
Code: [Select]
G54 G90 G91.1
G00 X32.5 Y-30 A0
G01 X-32.5 Y-30 F1000
G03 X20 Y-42.5 I30.5972 J16.2747 A90 F6000
G01 X-20 Y-42.5 F1000
G03 X32.5 Y-30 I19.9794 J32.3716 A180 F6000
G03 X20 Y-42.5 I30.5972 J16.2747 A270 F6000
G03 X32.5 Y-30 I19.9794 J32.3716 A360 F6000
M30
<a href="http://www.youtube.com/v/__VUE6ov0oU?hl=en_US&amp;amp;version=3" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/__VUE6ov0oU?hl=en_US&amp;amp;version=3</a>
Ian
« Reply #13 on: June 09, 2013, 08:10:13 AM »
Thanks for your help Ian. I will give your code a try when I get my table up and running.
Trying to find time to build so I can see the results
cheers
Ricky
« Reply #14 on: June 09, 2013, 07:02:56 PM »
Sweet Job... Ian
Offline stirling
  •  2,188 2,188
  • UK
« Reply #15 on: June 10, 2013, 03:04:53 AM »
Thanks Craig - Handy code btw if you want to open a corned beef tin and you lost the key  ;D
« Reply #16 on: June 10, 2013, 05:56:04 AM »
 :D
..... nice one, thanks  ;D
