Hello
Guest
it is
October 19, 2024, 11:36:56 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Blown spindle inverter/controller
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Blown spindle inverter/controller (Read 7330 times)
large519
29
on:
June 06, 2013, 06:56:37 PM »
Almost at the final hurdle and after finally sorting out the connections and getting my spindle turning correctly ..... the old spindle drive inverter/controller has given up in a puff of smoke, well it was nearly 30yrs old!!. Not yet sure how much damage has been done and whether it can be repaired, as I will get it checked out. But if it is damaged beyond repair, can anyone else recommend a suitable single to 3 phase inverter/controller?
My motor spec is as follows -
MAKE - ASEA
3Phase - 50hz IEC34 IP54
MT71B-F85-4 Class F
0.37Kw 380/380-420VY 1.3A
1400r/min 220/220-240V 2.3A
No.1470779 CoS 0.69
I have been recommended this one -
http://www.ebay.co.uk/itm/0-37kw-1-2HP-Single-Phase-In-Three-Phase-Out-Motor-Inverter-AC-Drive-NEW-/221180218416?pt=UK_BOI_Industrial_Automation_Control_ET&hash=item337f5e4c30
It does state -
Control Specification
Control Method
Voltage Vector
Energy Optimised
PWM Frequency 4…32 kHz (effective)
V / Hz Ratio Linear
Boost Yes
Stop Mode Coast / Ramp / DC Brake
Am I right to think that mach3 can control this via a pwm 5khz signal? via my diycnc sp4dc board
Any help will be very much appreciated
Logged
angel tech
499
Re: Blown spindle inverter/controller
Reply #1 on:
June 07, 2013, 04:53:46 AM »
the diycnc board gives you 0-10v output to run the inverter, and is run from the step and direction signal from mach.
when you setup the inverter you will need to set the max frequency to 100hz
Logged
jimthefish
303
Reply #2 on:
June 07, 2013, 07:59:05 AM »
Phone these or look at the site they are excellent and a good price.
http://www.inverterdrive.com
Logged
angel tech
499
Reply #3 on:
June 07, 2013, 09:41:11 AM »
gavin oseman is also keen on price. 01684574996
Logged
Chaoticone
5,624
Precision Chaos
Reply #4 on:
June 07, 2013, 10:56:06 AM »
I use a GS2 series drive from Automation Direct. It is single phase in 3 phase out. I control it via the digital inputs for manual FWD/Stop/REV and a speed pot from the control pendant switches or control FWD/Stop/REV and/or the speed from Mach via modbus. Modbus makes for a clean install and if your not going to need to be able to swap around form auto to manual control it is pretty straight forward to set up.
Logged
If you could see the things I have in my head, you would be laughing too.
large519
29
Reply #5 on:
June 11, 2013, 03:26:25 PM »
Blown capacitors, resistors and power transistors...... it's ruined,
Angel tech, what is the relevance of setting up the inverter frequency to 100hz, when the motor is only 50hz?
Logged
angel tech
499
Reply #6 on:
June 11, 2013, 04:29:41 PM »
to get double the speed
Logged
angel tech
499
Reply #7 on:
June 11, 2013, 04:41:13 PM »
your motor will probably run at 1425 rpm at 50hz, so if you set the inverter to run at 100hz max frequency you'll get approximately 2850 rpm at the motor.
Logged
large519
29
Reply #8 on:
June 11, 2013, 06:47:58 PM »
Ah ok, yeah as before the max rpm was 2500 when programmed through the original control, even though motor states 1400 rpm.
If I wire in a potentiometer to the new drive, is it correct that, that will make mach3 redundant for spindle control?
Logged
angel tech
499
Reply #9 on:
June 11, 2013, 06:51:07 PM »
yes, but why would you ?
Logged
Print
Pages:
1
2
Go Up
« previous
next »
