Hello Guest it is September 23, 2026, 09:17:24 AM
Author Topic: problem with mach2  (Read 11112 times)
problem with mach2
« on: August 03, 2013, 07:33:49 PM »
  Been running mach2 (4.x) since '07 with very few problems.  About 2 weeks ago, I started to notice that when loading a gcode file, occasionally  it kind of hung up or took twice as long to load.  Everything worked once it was loaded.  Starting last week, when I try to load a g-code file, it crashes and says mach1.exe must close.  Then, 1 or 2 minutes later, I get a blue screen of death that says"process has locked pages".  Am running windows xp home, no internet on the computer, some cad and office programs.  NO hardware or software changes were made to the computer although I do notice some keyboard errors that appear not to be fatal every once in a while.  Tried to read a bunch of stuff and at least I can avoid the blue screen by running the ocx.exe program twice after mach2 crashes.  Changed keyboards and re-installed mach2 with no changes.  Today, I figured out I can load a g-code program from the button that says "recent" files (I always name the programs a,b or c.nc).  If I try and load the same program from the "new" button it crashes mach2.  I did notice that the first line in the program is usually :0000, maybe this is with my particular setup, I don't know.  Sometimes it says O0000 (a capital o instead of a colon).  This doesn't affect the crashing behavior, but it is funny.
thanks,
jaime
Re: problem with mach2
« Reply #1 on: August 04, 2013, 05:10:25 PM »
To me it sounds like either your XP install is the problem or possibly your computer itself is dying.
« Reply #2 on: August 04, 2013, 06:39:16 PM »
  It makes sense that it would be related to getting the file from the computer.  But the file is in only 1 location so why should it matter if you navigate to it from the new button or the recent file button?  Not having any problems with cam program, excel or cad programs getting files.  Any ideas on how to test this????????/
thanks,
jaime
« Reply #3 on: August 05, 2013, 01:57:41 AM »
I would try a repair of XP, assuming of course you have the XP CD that you can boot from to do it.
  •  9,373 9,373
« Reply #4 on: August 05, 2013, 02:16:53 AM »
Jaime,
It’s a long shot but something additional you may wish to consider…
If you have one, try replacing the BIOS battery and reconfiguring to the optimum settings for your PC, graphics card, etc.(when these batteries go down, the BIOS can reset to default or cause other strange problems with a system that has previously run perfectly).
« Reply #5 on: August 05, 2013, 11:15:28 PM »
Thanks for the suggestions, will look into these ideas, thanks.
jaime
