Hello Guest it is October 06, 2026, 02:34:58 AM
Author Topic: how to override feedrate ?  (Read 7568 times)
« on: October 20, 2013, 11:32:33 PM »
Hi, it seems that the bars in mach3 in the override feedrate are not doing anything.
is there a way to enable/ disable it ? i'm moving the all of the sliders up and down and even trying to type a different value and nothing seems to work...
i can't even change RPM...
all of this while milling...
thanks in advance.
Sincerely, Guy.
Re: how to override feedrate ?
« Reply #1 on: October 21, 2013, 02:06:42 AM »
Only two things I can think of, No Feedrate on Queue in General Config is chosen or your code has a M49 in it.
If neither of these pleas attach your xml and I will see if I can find the problem.
