Hello Guest it is July 08, 2025, 01:00:40 AM
Author Topic: Can I test auto tool zero by  (Read 4034 times)
« on: December 09, 2013, 01:46:19 PM »
Hello; I was told, since I don't have any more input pins available, I could connect my auto tool zero plate "in parallel" with the A axis. As a test, shouldn't I be able to take the wires leading to my input limit switch (on A axis), then attach them to my alligator clips/ assign ports and pins correctly - and it should then work (providing I have the correct script). Is this correct? Thanks
Offline Fastest1
  •  920 920
  • Houston, TX
Re: Can I test auto tool zero by
« Reply #1 on: December 22, 2013, 10:44:21 PM »
It would depend how you have the switches set up NC or NO.
« Reply #2 on: December 22, 2013, 10:49:35 PM »
Thank you for the reply
