Good Morning -
We have recently built a CNC using Mach3, Kflop card, and running on XP. We are having a problem where the machine will stop with no error message. We have run the program several times thru with no problems but on the 3nd or so run the machine just stops. The last time it occurred two heads (Z & A) were moving down and one spindle stopped, the other kept spinning. Also the spindle height distance was different and it should have been the same. There is no error message. The hourglass on Windows XP spins until we reset the whole thing.
Thank you in advance for any suggestions.....
Nancy
