Hello Guest it is October 21, 2026, 10:33:32 AM
Author Topic: Error message  (Read 15287 times)
Offline Ken K
  •  11 11
Error message
« on: December 21, 2013, 12:07:54 PM »
 I am using the Mach3 lathe , and am getting an error message, "F word missing with reverse time g1 move"
 This does not happen, all the time, and never have it, when doing mill work. If i input a f 5.0 into code, it goes to next line, with same error code.
 Is there a fix, for this problem?
Ken K
Re: Error message
« Reply #1 on: December 21, 2013, 12:14:29 PM »
Sounds like your using G95 mode, which requires an F work on every line.
Offline Ken K
  •  11 11
Re: Error message
« Reply #2 on: December 21, 2013, 01:30:04 PM »
 There is no G95, in the code. How do you turn it off?
Ken K
Re: Error message
« Reply #3 on: December 21, 2013, 01:37:05 PM »
Try putting a G94 in the code
Re: Error message
« Reply #4 on: December 21, 2013, 02:22:34 PM »
G95   doesnt require a F word with each line as I dont do that and it runs fine for me.
Can you attach your code and also your xml please.
Offline Ken K
  •  11 11
Re: Error message
« Reply #5 on: December 21, 2013, 02:28:23 PM »
 Put in G94 F 5.0, only got a feed rate of .03 i/min., but cleared the problem, program ran
 Put in G94  F30.0 and things work fine.
 Ken K
Re: Error message
« Reply #6 on: December 21, 2013, 02:34:19 PM »
Lathes are better used in G95 in my opinion but its up to the user I suppose.
What was in your code previously for your feed?
Offline Ken K
  •  11 11
Re: Error message
« Reply #7 on: December 21, 2013, 03:24:37 PM »
 This is the code I am using. The only thing added was the G94 F30.0
ken K
Re: Error message
« Reply #8 on: December 21, 2013, 03:35:44 PM »
Your code has G93, ie Inverse Time Feedrate, that is why you got that message.
