Hello Guest it is December 26, 2024, 07:22:28 AM
Author Topic: Strange Things Occur  (Read 12450 times)
« on: February 20, 2006, 11:29:25 AM »
Yes, strange indeed. Well if I extend my arm toward the machine, and come within four to five inches of the frame. a limit switch triggers on. I haven't run any parts yet because of this occurrence. I have a two conductor wire, 22 gauge, taped to the mdf table with alum. tape, connecting the two limits to a shielded cable to my breakout board. It seems as if the electrical field of my body is grounding out the system, could this be so? Any ideas as to why this happens.
Offline John S
  •  111 111
  • Nottingham England
Re: Strange Things Occur
« Reply #1 on: February 20, 2006, 11:34:36 AM »
Have you ever worked on the busses?
Perhaps you are a bad conductor.
John S.
Art
« Reply #2 on: February 20, 2006, 12:03:02 PM »
Hi:
 Your indusing noise and using your arm as an antennae
  Use a debounce of 2000 in the config/log, does that help any?
Art
« Reply #3 on: February 20, 2006, 12:32:04 PM »
set debounce already at 2k and the index at 2k but it's still happening. Is it possible I may need to ground my machine to a bolt or screw ?
« Reply #4 on: February 20, 2006, 12:33:40 PM »
John S.
no but i was once a pilot. i piloted it from here to there. hah hah....
Offline Keith
  •  187 187
« Reply #5 on: February 20, 2006, 01:21:07 PM »
Try doing a 'twisted pair' for the wire(twist them,assuming they are solid,so they helix each other).The input must be a high impedance and I'll bet anything you're environment is nice and dry and you're arm is 'charged'
« Reply #6 on: February 20, 2006, 08:30:06 PM »
are your limit swithces wired normally open or normaly closed?
« Reply #7 on: February 22, 2006, 05:12:43 PM »
  I think they are normally open
« Reply #8 on: February 22, 2006, 05:48:21 PM »
you may have to put pullup resistors on the break out board at each limit switch input.
« Reply #9 on: February 23, 2006, 10:29:47 AM »
Well if I add them just as a precaution, what values would I need? Please add your recommendations. Thank you.
