Hello Guest it is December 14, 2025, 08:33:01 AM
Author Topic: G68, how digits are interpreted internally ?  (Read 5204 times)
« on: January 07, 2014, 05:12:07 PM »
Dear Forum.
I'm trying to drill PCB (Eching is done via photosensitive PCB and chemical etch process), so I slam the PCB to my spoil board.
Measure the board via. webcam, and calculate the Rotation needed. Fx:
G68 A0 B0 R-1.753
However when i run the G-code and look at the MDI-screen it say the rotation is -1.8
So is it internally handled as 1.753 or is it rounded to 1.8 ?
Best Regards, Bo.
Re: G68, how digits are interpreted internally ?
« Reply #1 on: January 07, 2014, 05:40:48 PM »
I suspect if you open the screenset in a screen designer and edit the string to add more places after the decimal it will show that it is resolved correctly.
« Reply #2 on: January 07, 2014, 05:44:11 PM »
Ok I have just done it, I put 8 positions after the decimal and typed in, seems to be Mach allows the rotation to 5 decimal place, bit more than anyone would ever need I suspect :)
« Reply #3 on: January 08, 2014, 10:12:02 AM »
Dear Sir,
Thank you for your prompt reply.
I also doubt that I will need 5 digits.
Never the less I'm now confident that I can proceed with this solution to PCB drilling.
Best Regards, Bo Andersen.
