Hello Guest it is December 26, 2024, 07:17:08 AM
Author Topic: Diagnostic Screen Confusion  (Read 6722 times)
Re: Diagnostic Screen Confusion
« Reply #10 on: January 13, 2014, 01:41:57 PM »
Dont see anything wrong with your xml and no the screening should not be a problem.
Offline kolias
  •  1,163 1,163
« Reply #11 on: January 13, 2014, 02:23:24 PM »
Thanks Hood but just got it working now. Don’t know if it matters but there is a dip switch on the BOB which controls the COM to either be +5V or GND. I switched that to GND, re started all and nothing then put it back to +5V restarted and now all works well including the limits. But I did put a 0.4mF capacitor on the limits and the probe.
But still have two hick ups. The most serious is that when I home the Y / A axes the gantry goes away from the home position. If I click on the reverse tick on the home/limits screen then my keyboard arrows are reversed and don’t like that because it gets confusing. Perhaps I can change on Y / A the active low tick from green now to red?
Also with the probe as soon as I touch the alligator clip to the bit I get the message "limit switch is triggered"
If you have any tips please let me know otherwise I will keep trying
Nicolas
Nicolas
« Reply #12 on: January 13, 2014, 03:48:25 PM »
To change the homing direction you choose Home Negative or not.
regarding the probe, sounds like either you have it connected to a wrong input, ie a limit or e-stop, or you have noise.
Offline kolias
  •  1,163 1,163
« Reply #13 on: January 13, 2014, 08:43:02 PM »
Got the homing direction ok, thanks Hood, and now from diagnostic screen when I click the X or Z to home nothing moves. The X and Z move nicely with the keyboard and the rest all working fine. Only he green light comes ON when I click to home X or Z. I attach my homing limits screen in case you can see something
Any idea why I cant home them two?
Nicolas
« Reply #14 on: January 13, 2014, 09:21:14 PM »
The X and Z home switches were not enabled in your .xml I downloaded yesterday
Offline kolias
  •  1,163 1,163
« Reply #15 on: January 14, 2014, 03:08:42 AM »
Thank you Gerry, my silly mistake which I noticed later
Nicolas
