Hello
Guest
it is
December 22, 2024, 01:20:52 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
checking jogging voltage pins
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: checking jogging voltage pins (Read 2269 times)
katadhin
18
on:
January 13, 2014, 02:04:31 PM »
I need help in checking the Y axis jogging pin to check the voltage. when i jog it down arrow key it goes up, the up arrow key goes up.
thanks rod
Logged
Carnoustie, Scotland
Re: checking jogging voltage pins
Reply #1 on:
January 13, 2014, 03:50:48 PM »
Change the active state of the Y's Dir pin, in Ports and Pins, Motor Setup.
Logged
Print
Pages:
1
Go Up
« previous
next »
