Hello Guest it is December 26, 2024, 07:26:19 PM
Author Topic: Can someone help with this error  (Read 6072 times)
« on: January 19, 2014, 03:36:50 PM »
I have a fully licensed copy of Mach3 and recently installed the latest updates(a week ago). I ran the machine several times after that with no issue. Today I did a couple of jobs and then this error appeared when I clicked cycle start. The machine ran normal after clicking OK on the error. The message appears after the cycle is complete as well. Attached is a picture (I hope) of the error. Thanks in advance.
ERROR, #Expand File not found at:
Chuck
Offline Vogavt
  •  260 260
Re: Can someone help with this error
« Reply #1 on: January 19, 2014, 03:55:06 PM »
Which version or Mach3 are you using?
I went looking for that path on my machine as it looked odd to me.
All my macros, i.e., *.m1s, are in macro folder and my *.set files are in the main Mach folder.
By the way, what screen resolution are you running on your PC?
The attached file, if it's a screen capture, is huge. 3264x2448 in size.
Since you reference the 1024.set, that's why I ask.
Maybe you did some photo editing to enlarge the snap shot, but I think for we'd be better served in the future, if you just typed out in the thread what the dialog box shows. You did do a portion of it, then we have to download a 3.5 meg file to see what your issue is.
Again, just for future reference.
For others, the dialog box in the screenshot states:
Error, #Expand File not found at:
C:\Mach\ScreenSetMacros\1024.set\Masters\Headers\CopyRightandLicenseNotice.m1s
« Reply #2 on: January 19, 2014, 04:01:42 PM »
That's an error message from the MSM screenset. If you've uninstalled it, then you didn't uninstall it properly.
« Reply #3 on: January 19, 2014, 04:01:59 PM »
Thanks for the reply, I am running version R3.043.066. Sorry about the picture, took it with my cell phone and did not change the resolution. I've posted before, but never a picture....I'll learn!
« Reply #4 on: January 19, 2014, 04:07:15 PM »
Not sure what MSM screenset is and I have not uninstalled any of the screensets. I have been using MachBlue probing big tex ver 3. I was switching back and forth between sets to see if that was where the error was coming from.
« Reply #5 on: January 19, 2014, 04:23:00 PM »
MSM = MachStandardMill from Calypso Ventures.
You must have installed it at some point, as it's the only screenset I know of that will give you that error.
« Reply #6 on: January 19, 2014, 05:52:33 PM »
Now the error actually shows up for every screenset I tried.
« Reply #7 on: January 19, 2014, 05:55:32 PM »
Yes, but it's the MSM screenset that's causing it.
« Reply #8 on: January 19, 2014, 06:25:21 PM »
You mentioned earlier that there was a proper way to uninstall it, can you help me out with that?
thanks
« Reply #9 on: January 25, 2014, 01:10:49 PM »
Gerry,
         Can you tell me what the proper method for uninstalling the screenset is?
thanks
