hello, still in demo mode.
the machine is an isel fb2 16mm with 5mm pitched threads
neama 3.1's bi-polar parrallel
drives are set 3.2 a and 2 micro steps
leafboy usb bob
only two issues!!!
draw a box 100mm by 50mm in corel, export it as a dxf to corel cad.
import that into lazy cam - make the g-code.
send it to mach3,
the problem is the machine moves a mere exact half, 50 by 25mm instead of 100 by 50mm
do i change the 'steps per' from 400 to 800?
velocity stays at 750?
acceleration 24
is it better to have 'more' micro steps set on the drives than 2?
i.e. if I have 2 steps at 800 steps per - if thats correect?
can I have 20 steps at 8000
or is that not how it works?
ALSO, my Z axis is set up just as the X and Y axis are - they trun the corrcet way, but the Z turns the wrong way goes up instead of plunges, and goes down at the end of the box
is that a wireing issue? as I changed the a- and aaaaaaaa+ around and the b+ and b- around and it dint make any difference.
thank you please
p.s. who do I send the pay-pal to?
