Hey folks,
I have a new problem.
Been threading with this set-up for several years, thousands of identical parts.
I'll have to retrieve the version, but think its 22.
Suddenly, the rpm is bouncing around +/- 4 onn the Mach screen and about half that on the VFD readout.
This of course ruins a 48 pitch thread (5 passes).
It used to only fluctuate 1 rpm.... maybe 2, but mostly 1 and made acceptable threads. Sometimes 1600 pcs. non stop.
Quite by accident, I noticed that closing Mach, then restarting the rpm was stable again.
Then I checked the diagnostics, not sure though if it was fluctuating or not at the time. But, here is what it reported:
Time in int. 4 > 11
CPU speed 2018.0
Pulse Freq. 44023
The kernel is set a 25
This is PPort, PMDX 122 BoB - PMDX 106 Spindle control.
I'm trying to narrow it down to .... the PC ? the 106 ? ... or the inverter ?
We opened the pc case and blew it out (was very dirty) thought the cpu might be overheating .. didn't help.
Never know when it might happen, sometimes instantly ... might be good for a day or two. Regardless, much too frequent now.
Any help troubleshooting would be much appreciated,
Russ
