I have also trouble with motors not moving. Can someone helps me please?
it is like lpt doesn't work or software doesn't recognise ports.
Also when pressing stop button on controller board macg3 does't recognise it was pressed!
my settings is the same as this
Port 1 (0x378) Matches what I have in system settings
Kernal Speed 25000
Pin Setup
X Axis Step Pin 2, Dir Pin 3 (Dir Low) (Step Low) Step Port 1, Dir Port 1
Y Axis Step Pin 4, Dir Pin 5 (Step Low) Step Port 1, Dir Port 1
Z Axis Step Pin 6, Dir Pin 7 (Step Low) Step Port 1, Dir Port 1
Probe Port1, Pin 15, (Active Low)
Estop Port 1, Pin 10, (Active Low)
Enable Port1, Pin 14
Motor Tuning
X Axis Steps Per 200, Velocity 2000, Acc 200, Step Pulse 3, Dir Pulse 1
Y Axis Steps Per 200, Velocity 2000, Acc 200, Step Pulse 3, Dir Pulse 1
Z Axis Steps Per 200, Velocity 800, Acc 150, Step Pulse 3, Dir Pulse 1
