Hello Guest it is December 26, 2024, 03:25:42 PM
Author Topic: Change height for mach3  (Read 2533 times)
« on: March 10, 2014, 07:13:34 AM »
Hi!
How can I chnge the height in Mach3?
I'm using Vcarve and it's allways 25.4 for the Z How can I change that so it wont drill straiht in to the board?
Thanks!
Re: Change height for mach3
« Reply #1 on: March 10, 2014, 11:49:20 AM »
You need to change it in V-Carve Pro.
« Reply #2 on: March 10, 2014, 07:06:06 PM »
As ger21 said, you need to change your settings in VCarve.
In the toolpaths tab, the first icon is "Setup material and rapid gaps". You can change the retract height there.
