Hello Guest it is September 21, 2026, 02:17:32 AM
Author Topic: pulling my hair out......!!!! :)  (Read 18880 times)
Re: pulling my hair out......!!!! :)
« Reply #10 on: April 27, 2014, 04:37:03 PM »
I hope this is right..... I simply divided the current 10160 by 25.4 and got 400.  I put that as the steps per and it now moves only 1mm.  The only thing that looks off is the motor tuning display "arc" is almost flat looking instead of a ramping up, leveling off, then ramping down again.  Not sure if this of any concern or not......
Again...thank you much for the help!!!
« Reply #11 on: April 27, 2014, 04:45:26 PM »
Once you change the steps/unit, you'll also need to redo your velocity and acceleration settings.
