Hello Guest it is September 17, 2026, 05:53:59 PM
Author Topic: MAX-NC Wave pin mapping to Step & Direction  (Read 10613 times)
« on: March 15, 2007, 05:35:42 PM »
I can't figue out how to assign the printer port pins on my MAX-NC-10 (the open loop version) to the MACH 3 configuration page.
MAX-NC-10 uses four pins per stepper motor.  Step and Direction only gives me two pins per motor.
Assuming that at least one forum user has a MAX-NC-10 working with MACH 3, can you please tell me how you did it?
Thank you
Brian
Re: MAX-NC Wave pin mapping to Step & Direction
« Reply #1 on: March 15, 2007, 05:55:35 PM »
If you look under ports and pins setting there is a choice for either MAXNC or MAXNC CL. You want MAXNC. It automatically assigns the pins. 4 per axis X,Y & Z. It uses all 12 outputs of one PP.
Darek
« Reply #2 on: March 16, 2007, 12:25:24 AM »
Hello Darek,
Thanks for the tip but it does not do it for me.
I have gone to Config\ports and pins\ check MAXNC Wave Drive clicked apply then restarted.  The \motor outputs\ screen still shows just a single step pin and a single direction pin.
I am still missing some key information to get started.
Brian
« Reply #3 on: March 16, 2007, 04:52:59 AM »
The motor outputs screen settings do not matter in MAXNC modes. They are preset to match the MAXNC controller. Putting #'s in them boxes will change nothing.
Darek
