Hello Guest it is September 11, 2026, 03:51:11 PM
Author Topic: DRO's show Movement - Stepper Motors Dont Move  (Read 10787 times)
« on: May 20, 2014, 07:24:54 PM »
I recently Purchased a Sanven 6040 desktop CNC through Amazon.  I set it up and was able to Jog by using the arrow keys .  I tried to set the X, Y and Z zeros now The DRO's show movement but the stepper motord\s don't budge an inch. Has anybody else experienced this and if so what did you do?
Re: DRO's show Movement - Stepper Motors Dont Move
« Reply #1 on: May 21, 2014, 05:01:04 AM »
Could be many things but first thing to check is the correct port address is set in Mach.
« Reply #2 on: May 24, 2014, 05:45:18 PM »
Hi Hood,
Thanks for responding to my post.  You brought an interesting point.  My computer has Port 1 taken up by the Mother board.  I waqs wondering if you had any ideas?  Thanks
« Reply #3 on: May 25, 2014, 02:01:21 AM »
Look in device manager for the port address. What Windows calls the port is irrelevant, it could be LPT1 or 3 or 20, all that matters is you put the correct address in the box in Mach.
If you attach your xml I will takle a look at that and see if there are issues with your config.
« Reply #4 on: May 25, 2014, 04:07:10 PM »
Hi Hood, I don't know what an XML is or how to h\get one (:
