Hello Guest it is September 25, 2026, 02:48:14 AM
Author Topic: New to Mach and a question  (Read 8919 times)
« on: May 23, 2014, 04:03:24 PM »
Hi, im new to Mach 3 and CNC. I built a CNC router and have the controller and motors connected. The problem I have is I have a Toshiba laptap running windows 8. I was reading posts that I need a USB controller, any suggestions? also, does the USB controller replace the controller that came with the motors? Thank you
Re: New to Mach and a question
« Reply #1 on: May 23, 2014, 04:25:18 PM »
What did you actually get with the motors? Probably just a breakout board? If it is, then you'll probably still need it, depending on which motion controller you use.
Take a look at the UC-100 or Smoothstepper.
« Reply #2 on: May 23, 2014, 04:36:56 PM »
its a covered plastic box that the motors connect to, it has on/off and spindle speed control and parallel port connection
« Reply #3 on: May 23, 2014, 04:44:11 PM »
The USB motion controller will have a parallel port connection, that you should be able to just plug into your box.
The box most likely contains a breakout board, power supply and stepper drives.
