What about status of DT plug in now? I had lot of experience with DT controllers and don't understand following.How do you use PMAC together with Mach? PMAC is very powerful solution and capable to control by a machine itself. Only HMI is need for a complite CNC system on a PMAC.Mach isn't simple HMI, it is complite CNC system wich consists HMI, path processing,interpolator and so on.It means that from the Mach we will use only little bit its capabilities isn't it?.If it will be so when why do somebody pay for a set of Match and PMAC?.It will be easy to create your own HMI or ready to use software istead.
