Trying to learn A axis programming. I have just installed a second parallel port built a G540 with power supply and activated A axis pins and ports. My motor is 200steps per rev.* 10microsteps per rev.*2 "for 2 to 1 gear ratio, 30 teeth headstock 15 teeth stepper"/360°= Steps per 11.1111 Motor Tuning
All seems to be working in MDI code input have not checked with indicator but 360° and 0° are 12:00 180° is 6:00 etc..., but when I run this code the "G01 A360.0 F150" is over rotating by many times before continuing to next line.
I have "use radius for feedrate", "A-rotations enabled" in Config/Toolpath, "A axis is angular", "Ang Short Rot on G0"Config/General Config, "Rotation Radius A.0010" Settings Alt-6
Here is my troubled code.
G00G17G90G40G49G80
T1M06
G00G43Z0.700H1
S20000M03
G94
G00Y-0.187
G00Z0.500
G01Z0.389F75
A360.0F150
G01Y-1.437A-2666.667F150
G01A-2306.667F150
G00Z0.489
G00Y-0.187
G00A0.0
G01Z0.377F75
G01A360.0F150 Over rotates by multiple full revolutions
Any info is appreciated
