Hello
Guest
it is
October 06, 2024, 04:40:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
setup questions from newbe
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: setup questions from newbe (Read 2914 times)
idekkers
3
on:
June 20, 2014, 04:52:25 PM »
Hey there
I'm setting up my first CNC machine, and I have a few questions I hope you can help me with:
my setup is this:
Drivers:
http://www.wantmotor.com/ProductsView.asp?id=257&pid=82
PS:
http://www.aliexpress.com/store/product/Best-Selling-Wantai-Single-Output-Power-Supply-350W-36V-S-350-36-for-CNC-Router-Grind/511874_677179176.html
motors:
http://www.wantmotor.com/ProductsView.asp?id=160&pid=80
the 57BYGH115-003 (second from bottom)
so my 2 questions are:
1. how do I set the jumpers on the drivers ?
2. I see 2 setups for the wires from the pul and dir pins - one is to connect the positive pins to the BOB power supply +5 and the 2 negative to the BOB control pins,
and the other is to connect the negative to ground of the BOB and the positive to the control pins.
does it matter which setup?
thanks so much for your help
Logged
Carnoustie, Scotland
Re: setup questions from newbe
Reply #1 on:
June 21, 2014, 04:45:50 PM »
What , if any, breakout board are you using?
Logged
idekkers
3
Reply #2 on:
June 21, 2014, 05:34:28 PM »
Thanks for the reply
the BOB is the one that comes free from Wantay:
http://www.aliexpress.com/item/Germany-free-shipping-3PCS-stepper-motor-driver-DQ542MA-4-2A-50V-128-Micro-CNC-Router-Engraving/1856844353.html
Logged
Reply #3 on:
June 22, 2014, 08:11:32 AM »
Dont see any details about the BOB itself, maybe missed them. What I would say is look at the BOB and see if the common is 5v or 0v and then choose the setup of your drives to suit.
Logged
idekkers
3
Reply #4 on:
June 22, 2014, 02:23:55 PM »
will do, thanks
but what about the jumpers on the drivers?
is it possible to fry something if I don't set anything? or is the setup or is any setting "safe" in this setup and it's just a matter of power and speeds?
Logged
Print
Pages:
1
Go Up
« previous
next »
