Hello Guest it is October 04, 2026, 12:13:11 AM
Author Topic: using function sin-1 in a brain  (Read 22900 times)
« on: June 26, 2014, 07:51:07 AM »
i have an RC servo controlled coolant nozzles that needs to find the angle using the sin-1 (arcsin). I just can't seem to get it to work.
 the formula is from this site      http://www.mathsisfun.com/algebra/trig-solving-sas-triangles.html
 using example 2. It works up till the last part   sin P / 6.9 = sin(117°) / 8.405...
        sin P = ( sin(117°) × 6.9 ) / 8.405...= 0.7313...
        P = sin-1(0.7313...) = 47.0° to one decimal place
  To check my math i did each step in a different brain.
  In the tool height DRO put 6.9
 I tried putting .7313 in the DRO with a brain with the formula  arcsin(a) and still get .8202
 The sin-1 of .7313 should be 47 but i get .8202 Is it a bug or am I doing something wrong?
 formula arcsin(((0.891)*a)/(sqrt(a^2+2.6^2-2*a*2.6*(-.4539)) puts out .8202
 Is there a better formula to use? The information that i have is 2 sides and one angle of the triangle.
   https://www.youtube.com/watch?v=_tZ03tWGnL8&list=UUcIK-PynOymd_15wWIhGyHg
Re: using function sin-1 in a brain
« Reply #1 on: June 26, 2014, 09:15:35 AM »
.8202 is the arcsin in radians. You need to convert radians to degrees
.8202 * 180/pi = 47 (46.995)
« Reply #2 on: June 26, 2014, 10:51:20 AM »
thank you.
set my calculator on rad and get .8202
