Hello Guest it is December 30, 2024, 12:19:38 PM
Author Topic: Noob in need of assistance. Home switch issue.  (Read 2906 times)
« on: July 26, 2014, 08:45:09 AM »
Good morning. I am setting up M3 with a Gecko G540. I am having an issue with my x and z axis while homing. The M1, M2, M3 lights all illuminate on the diagnostic screen when I manually activate the switches. However when I reference each axis the y is the only one that stops and backs up. The others dont stop I have to hit the e switch. I am using the xml file available from gecko. The link is to the schematic that I used for wiring. Thanks in advance for the help, Doug
https://dumpyourphoto.com/files4/103013/0XSKAo.jpg
Re: Noob in need of assistance. Home switch issue.
« Reply #1 on: July 26, 2014, 04:52:35 PM »
Please attach your xml.
« Reply #2 on: July 26, 2014, 05:51:09 PM »
I will when I get home from work this evening. Thank you.
