Hello Guest it is December 26, 2024, 07:23:48 AM
Author Topic: Pattern troubles  (Read 2679 times)
Pattern troubles
« on: July 28, 2014, 10:02:37 PM »
Pattern g code when loading in mach3, doubles in size when cut.
Any ideas on what is going on?
Re: Pattern troubles
« Reply #1 on: July 29, 2014, 12:53:33 PM »
Maybe I have worded the first post incorrectly,
What is going on is, if I load a pattern (G Code) that is say 9.5 inches wide by 4.5 inches high, in the passed it has been cutting it correct. Now I load the same pattern (G Code) into Mach3 it is making it twice the size.
Any setting in Mach 3 that may have gotten changed by mistake?
Have checked everything I can think of, to check.
Any help on what could be going on here?
« Reply #2 on: August 03, 2014, 02:14:11 PM »
Only things I can think of that  could do that are your code has a G51 in it or your steps per unit are half what they should be or lastly you have a scale set in the boxes next to the DROs.
