Hello Guest it is December 21, 2024, 12:04:10 PM
Author Topic: M3 Automation  (Read 2340 times)
M3 Automation
« on: October 02, 2014, 12:05:58 AM »
Hi all
I've been using VCarve and Mach3 for a while now but I've always been starting the spindle or what ever I'm controlling manually.
I want to now move to automating this process, can I set the M3 and M5 to be loaded when Vcarve produces its tool path or do I have to add these to the gcode once it's saved as the txt file? Or do I set it in Mach3?
I use the Gecko G540 stepper driver if that makes any difference...
  •  9,279 9,279
Re: M3 Automation
« Reply #1 on: October 02, 2014, 01:35:36 AM »
Yes, it's as simple as that.
