Hello Guest it is February 27, 2025, 08:58:34 PM
Author Topic: Jog keys  (Read 5979 times)
Jog keys
« on: October 08, 2014, 12:27:00 AM »
OK, yet another noobie question.  Where's the Z jog key?  I have arrow keys, with ctrl or shift, for XY, but where's Z?
Re: Jog keys
« Reply #1 on: October 08, 2014, 12:47:16 AM »
Hi Anniepoo:
Welcome to the Mach3 Forum.
Go to the "Config" menu at the top of the page. Scroll down to "System Hotkeys". The table "Jog Hotkeys" is where you set the key for an axis. If you click on the Z++ button, and then hit the key you want for the Z axis "UP, that key code will appear in the box. Click on the Z-- button, and hit the key you want for the Z axis "down."
Most people use the PgUp and PgDn keys for the Z axis.
After setting the Z keys, and clicking the OK box,  scroll down to the bottom of the config menu, and click on "Save Settings."
John
Re: Jog keys
« Reply #2 on: October 08, 2014, 01:00:29 AM »
8cD  Thanks!
mine are now set to pgup and pgdwn, and the CNC's happily cutting air on a test run.
