Hello Guest it is June 05, 2026, 04:39:13 PM
Author Topic: MB Asrock AM1B-ITX + C10  (Read 7907 times)
« on: November 13, 2014, 10:32:11 PM »
    I'm replacing my cnc lathe MB to Asrock AM1B-ITX, this board has a LPT port on board but I'm having problem getting this port to talk to C10. Previous MB had no problem is just a little bit old.
I checked the Bios settings in AM1B-ITX, Pararellel port is enabled, Device mode = Normal ( other 3 options = Bi-directional, ECP and EPP 1.9 mode, ECP and EPP 1.7 mode). Reload pc, enter Mach3 jog xyz result = no movement. DC servo are energized/locked.
Images:
Anyone experienced this before, and how did you overcome this problem?
thanks,
Re: MB Asrock AM1B-ITX + C10
« Reply #1 on: November 16, 2014, 02:35:47 AM »
Found some answer from other forum:
http://www.kellyware.com/kwforum/discus/messages/3/2863.html?1370554176
I re-installed the OS to Win7 Pro 32 bit, now is all working.
