I also bought a computer running 7x64 with a smoothstepper. You should know that as far as I can tell, Mach 3 torch height control is dependent on having the port driver installed. As far as I know the thc function is the only way to adjust the z axis through Mach while cutting. At this point, I'm going to try uninstalling the 64 and installing the windows 7 32 bit so that I can at least install the port driver. I am hoping that this at least will fully enable the thc in Mach even though I don't have a printer port. Bear in mind that I am also a newbie. If more experienced users have something to add or think I'm wrong, their probable right.
