Relying on a timer for plasma ignition is only ok if your plasma unit has a consistent preflow time and reliable ignition. (some plasma units have a short preflow time if the postflow is still on, this messes up timed starts at your cnc).
The best way is to hold machine motion until the plasma lights. Most plasma units have an arc on output (contacts).
In your case, I suspect they're not connected, you would have had to use an input pin and a macro
Sorry I can't help more, since I'm new to mach3, and don't have a plasma cutter, but I'm sure this has been done before. I would also like to implement a plasma interface, I see the thc controls, is there any documentation out there that descibes their use and implementation? I can't find any.
