Hello Guest it is October 14, 2026, 03:38:45 PM
Author Topic: Mach3/USB SmoothStepper will not control spindle speed  (Read 174748 times)
Re: Mach3/USB SmoothStepper will not control spindle speed
« Reply #30 on: July 25, 2015, 10:10:30 AM »
Has anyone been able to get a touch probe to work through the ESS?? I can see the "Digitize" input go green in mach diagnostics, and I can see pin 10 activate in ESS diagnostics but the Z isn't stopping as it should. Using the same script I used before the ESS.
