Hello
Guest
it is
July 27, 2024, 12:05:48 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
How to swap the x and y axes
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to swap the x and y axes (Read 3007 times)
golash
81
on:
January 27, 2015, 03:47:02 PM »
Hi
I`d like to swap my x and y axes in mach 3. Do I just switch the motor specs in the motor
tuning section of Mach 3. In addition do I need to switch the connectors to the motors
and switch the step and direction from the Gecko 320s to the BOB.
Logged
golash
81
Re: How to swap the x and y axes
Reply #1 on:
January 30, 2015, 07:58:14 AM »
Hi
I found the answer. I switched the x and y pins in motor outputs and switched
the specs in motor tuning. I believe switching the motor tuning was necessary
because each motor has a different pulley ratio for the servo motors.
It was not necessary to switch the motor connectors or switch the step,direction
and commons from the Gecko to the BOB
Logged
grouchy
11
Reply #2 on:
January 31, 2015, 12:32:18 AM »
when your done, save this setup as a different profile, then when you start mach3, you can choose which orientation you want to load
Logged
saab9395
6
Reply #3 on:
February 10, 2015, 03:31:40 AM »
i dont see the specs. in motor tuning. can you tell me where they are?
any help
Saab
Logged
golash
81
Reply #4 on:
February 10, 2015, 08:22:37 AM »
Hi
I was not clear. What I meant was the settings for motors velocity and acceleration. Which
are user defined.
Logged
Print
Pages:
1
Go Up
« previous
next »
