Hello Guest it is November 15, 2026, 07:23:37 PM
Author Topic: new button and led  (Read 33145 times)
Offline amnon
  •  40 40
Re: new button and led
« Reply #10 on: February 07, 2015, 01:24:41 PM »
Code: [Select]
SetOEMDRO(818, 10000)
If GetOemLed (14)=0 Then
'Code "(I am turning on Joge)"
DoOEMButton(103)
Else
End If
« Reply #11 on: February 07, 2015, 02:06:50 PM »
Try this
If GetOemLed (14)= 0 Then
DoOEMButton(204)
End If
Offline amnon
  •  40 40
« Reply #12 on: February 08, 2015, 08:02:29 AM »
Thank's Hood,
But, what code should I add to this one, to turn on my LEDS
Amnon
« Reply #13 on: February 08, 2015, 08:04:51 AM »
What is the LED to signify and when do you want it on and when off?
Offline amnon
  •  40 40
« Reply #14 on: February 08, 2015, 08:14:06 AM »
Signification of my LED is to show me that my button was pressed. So I want it on, when feed rate is changening by pushing my button.
Amnon
« Reply #15 on: February 08, 2015, 12:59:36 PM »
It would be a very simple matter to turn the LED on but the problem would be turning it off again when the circumstances had changed, ie the DRO does not have that value in it or the Jog mode is other than continuous.
What you would need to do is use the macropump or a Brain for that rather than trying to do it from within the button itself.
You would just look at the value in the DRO and the state of the Jog LED and if both were right you would turn the User LED on, if they were not both in the right state then turn it off.
« Reply #16 on: February 08, 2015, 01:21:58 PM »
Just tested this in the macropump and it works fine.
If GetOemDRO(818)=10000 And GetOemLED(14) Then
SetUserLED(2000,1)
Else
SetUserLED(2000,0)
End If
What you will need to do if you do not already have the macropump is firstly go to General Config page and enable the macropump.
Then Operator menu and VB Script editor. In the window that opens paste the code above then save the file as macropump.m1s  making sure you save it to the macro folder of the profile you are using.
You will then need to add a User LED to your screenset and give it the OEM code of 2000.
When you next open Mach it should light the LED if the DRO is 10000 and the Jog mode is Continuous, as soon as either of these change the LED should go out.
Offline amnon
  •  40 40
« Reply #17 on: March 08, 2015, 11:46:23 AM »
Hej Hood,
Your code works fine, now I try to add next UserLED to probe button. My intension is to set my LED when a probe button was pressed, and turn them off when probing is finished. I add to macropump
Code: [Select]
If button34 = 1 Then
SetUserLED(1406,1)
Else
SetUserLED(1406,0)
End if
but It doesn't work.
It is a little strange for me, that all buttons with my different macros have the same number 34. Can I change a button number?
Amnon
« Reply #18 on: March 08, 2015, 05:11:41 PM »
Where do you get the code
If button34
from?
Offline amnon
  •  40 40
« Reply #19 on: March 09, 2015, 01:05:25 AM »
I found this part of code in some macro.
Amnon
