Hello Guest it is September 17, 2026, 10:23:25 AM
Author Topic: RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START  (Read 39621 times)
Re: RADIUS TO END OF ARC DIFFERS FROM RADIUS TO START
« Reply #20 on: February 03, 2015, 05:04:26 AM »
Either attach or email both the bbcd and the xml and I will take a look.
« Reply #21 on: February 03, 2015, 03:49:41 PM »
Mick,
 loaded your bbcd and dont see a problem with it however the code is not good. I tried changing to dia mode but still it was not good.
 If I use my PP and use Dia mode (what I always use) then it is fine, well as long as Mach is in Dia mode as well.
So something wrong in the PP I think when it comes to rad mode. See what BobCAD say when you get them to do a PP for you.
« Reply #22 on: February 03, 2015, 04:26:19 PM »
Cheers Hood for taking a look.
Mick
