Hello
Guest
it is
September 14, 2026, 10:43:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Lathe Tool Turret
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Lathe Tool Turret (Read 10633 times)
slowtwitch
64
Lathe Tool Turret
on:
February 09, 2015, 02:13:55 PM »
Hello Folks, I'm playing with a spare Emco 120 tool turret. I would like to change the current DC motor to a stepper motor. I have the mechanics figured out and even have a macro for it. My question is .... what axis do I use to run it
thanks
pete
Logged
Carnoustie, Scotland
Re: Lathe Tool Turret
Reply #1 on:
February 09, 2015, 04:37:30 PM »
It will likely be best to use one of the rotational axes as you can then use roll over, then again all depends how you have done the macro. Other than that I do not think it would make any difference which axis you choose.
Logged
slowtwitch
64
Reply #2 on:
February 09, 2015, 05:40:38 PM »
Thank you Hood for the quick reply. If I were to use the rotational axis and using angles, would it be possible to reverse the movement of the turret a bit to snug up against the pawl in the turret. Being that this is an EMCO turret.
Again Thank you
Logged
Reply #3 on:
February 10, 2015, 01:48:46 AM »
Yes, should not be a problem.
Logged
slowtwitch
64
Reply #4 on:
February 10, 2015, 08:28:48 AM »
Again, thank you Hood !!!!
Logged
Print
Pages:
1
Go Up
« previous
next »
