If it has a variable speed motor then likely it has a VFD already, either that or it is a DC motor and even then it must have a speed controller if it is variable speed.
Regarding the CSMIO, just make sure it is either an IP-A or IP-S if you want threading as the IP-M cant do Lathe threading, or for that matter rigid tapping.
