I use Dolphin CAM to generate the code for my lathe and have all my tools with their tip radii & direction setups saved in Dolphin. I have the tool X & Z offsets saved in the Mach Tool table but noticed today that I don't have their tip radii & directions saved.
Will the Dolphin generated toolpaths (with tapers or radii in the work) all be incorrect because of that? If not, surely any Mach Wizard generated code with tapers or radii will be wrong, yes? Will I need 2 tool tables?
Just when I think I'm getting this stuff clear in my head, I realize how very little I know.
Fortunately, it hasn't made much difference in the low precision work I've turned out so far but I need to get this issue correctly sorted.
Also. is the Direction box in the standard Turn Tool Table screen input expressed in degrees from 0?
