Do I have to use 'Exact Stop' rather than 'Constant Velocity' when backlash compensation is enabled (R3.043.066)?
After a long time chasing lost steps have now found that this is linked to backlash compensation. Lost steps has been as much as 9mm in one go - (between changes in direction?). The feed rate speed was increased to 750mm/min for this test.
When backlash compensation is turned off no steps are lost, even at this feed rate.
Lost steps have been reduced by lowering the Backlash % max speed setting from the initial 20% to 10%. At 20% speed there ia a loud clonk on changing direction as compensation takes up the slack. (Steps lost) At 10% the movement is less violent.
Have also set 'Exact Stop' but would prefer to be in 'Constant Velocity' for better finish.
Any other experience/advice would be welcome.
Machine is Wabeco f1220E with upgraded 3.5Nm nema 34 stepper motors with G540 driver. 48v power supply.
The backlash Compensation is set to X 0.06, Y 0.04, Z 0.04
Feed rates have been reduced to 500mm/min acceleration set to 90. Step pulse set to 4 .Dir pulse at 3
