Hello Guest it is August 31, 2024, 07:08:49 PM
Author Topic: MilWiz bug ?  (Read 9299 times)
MilWiz bug ?
« on: February 28, 2015, 05:29:11 PM »
HIYA Ron, I think I found a bug. When doing a circular hole pattern whith circle OR pocket I get this error. WHICH is wrong the values are correct. IF I use a -1.000 in the example I get this error IF I use +1.000 I also get an error that teh depth is greater than the Ztop which would be correct.
Re: MilWiz bug ?
« Reply #1 on: February 28, 2015, 07:59:18 PM »
At a zero step depth it is going to take a lot of cycles to get to 1 inch.
Re: MilWiz bug ?
« Reply #2 on: February 28, 2015, 08:54:26 PM »
DUH, all I saw was PECK  and it did not seem to apply. And the message was about DEPTH so I missed it by a mile(;-)
Thanks (;-)TP
