Hello Guest it is December 26, 2024, 07:21:40 AM
Author Topic: OT- Welder for transformer  (Read 10022 times)
« on: April 17, 2007, 06:42:23 PM »
A bit off topic  ::)
Just wondering if anyone could tell me if an oil cooled welder could be used as a power supply for my servos. I have an Oxford 140Amp Oil cooled welder that I never use, it has a 50V and 80V output terminals, I am needing 50V so that would just be perfect. However there must be somthing different in a welder compared to a normal transformer as the current is selectable on a welder.
Anyone have thoughts on this?
Re: OT- Welder for transformer
« Reply #1 on: April 17, 2007, 07:05:27 PM »
You sure are thinking Hood. Better be careful, might see some smoke from your head. :D I think it should work. Put your meter across the terminals and adjust until you get 50vdc. Then set you meter on ac and that will give you an idea of the ripple it is going to have. Not sure but it sounds like a good thing to test.
« Reply #2 on: April 17, 2007, 07:11:08 PM »
No chance of that, thats why I have no hair, its a form of air cooling ;)
Not sure I follow what you are saying , mind you theres nothing unusual in that as its quite hard to follow a rednecks train of thought :D
The welder is AC and I will need to rectify it. The outputs are 80V and 50V both AC, the adjustment is for amperage.
« Reply #3 on: April 17, 2007, 07:19:49 PM »
Hood, If you can get the voltage you need and it is clean, it should work I would think. As long as you have enough amps. Their is no such thing as a power supply being too big unless it makes your power meter spin off of the wall or is supplying too much voltage. If you can get the right voltage and enough or more amps, I think it will work.
Edit,
I meant to say, you should be fluent in Red Neck by now.
« Last Edit: April 17, 2007, 07:21:57 PM by Chaoticone »
« Reply #4 on: April 17, 2007, 07:25:08 PM »
Well these things weld at 140Amps all day long so that wont be a problem, I am just worried that it cant be like a normal transformer as the voltage varies as you go between different tappings on a transformer.
 Will eat my porridge tomorrow and go fetch it from the old workshop and see what its like, well I know what its like, its green and  its flippin' heavy ;)
Offline rcrabb
  •  146 146
« Reply #5 on: April 17, 2007, 08:44:12 PM »
I would check it with a scope just to be sure its clean DC. Otherwise I think it should work.
Ryan
« Reply #6 on: April 18, 2007, 02:26:34 AM »
Thanks, the DC should be OK once I rectify/smooth  it but will make sure I check before I hook things up to it, dont want to let any more magic smoke out :D
ynneb
« Reply #7 on: April 18, 2007, 03:15:01 AM »
Once rectified and smoothed, the AC voltage of 50 Volts will become 70 Volts DC.
This is caused by the full wave rectification. I assume you know this ?
You multiply the AC voltage by 1.4 to establish the DC voltage.
EDIT : When AC voltage is measured, because it has waves with peaks, the peaks are not measured, but an average is measured. (RMS) (Root Means Squared) one you are converting both sine waves to one side and you then smooth between the peaks, the average Voltage becomes a constant voltage. Hence a little higher than AC
« Last Edit: April 18, 2007, 03:23:54 AM by ynneb »
ynneb
« Reply #8 on: April 18, 2007, 03:38:31 AM »
I did this a few years ago and always look for an excuse to replublish old works  :-[
« Reply #9 on: April 18, 2007, 03:42:23 AM »
Ha ha, thanks Benny, yes I did know but it does no harm to post it.
I am looking for 80v dc so 55V ac would be better for me but 50 will have to do :) My mains is about 440 across phases so I might get nearer the 80V that I am seeking.
