Hello Guest it is December 21, 2024, 10:43:44 AM
Author Topic: Mach3 command for auto tool change torch and lazor marker, seperate jobs, pos  (Read 35271 times)
The lazer T1 will mark on the sheet, and the the hand can pick up the torch and start cutting, marking and cutting are 2 difference jobs without any related, i just want the lazor to create mark on the products that were cut out. And i dont know what code i should right in mach3 and macro, because there is a subtraction between coordinates of the torch and the lazer marker so there will be an off distances when it start, so the problem is at the coordinates of the tools.
