Hello Guest it is September 15, 2026, 06:31:29 PM
Author Topic: EStop and IsMoving Timining  (Read 22111 times)
Offline SSPW
  •  26 26
« on: April 14, 2015, 10:11:12 AM »
I am wondering if anybody can tell me the how IsMoving reacts after an EStop is triggered.
When an EStop is triggered, i assume Mach3 decelerates all the axises at the maximum rate, and when the axis is stopped, then resets IsMoving.
Can any of the brain experts confirm this?
I would like to set an output when an estop triggers and reset the output after short delay on the IsMoving is reset.
Re: EStop and IsMoving Timining
« Reply #1 on: April 14, 2015, 06:21:55 PM »
Estop does NOT deaccelerate the axis it simply dumps the buffer . You will loose positon .
« Reply #2 on: April 14, 2015, 06:29:01 PM »
NEVER push the big red button while moving, unless you really really really need it to stop!
