I recently converted my Bench milling machine for all 3 axis.
I was checking accuracy on some cuts and came up with the following numbers.
Desired Circular Pocket drawn at 50mm Diameter and cut using a 10mm end mill. Result was a nice pocket but came out at 46.98mm :-(
Desired 75mm square profile using 10mm end mill. Result was 77.91 x 77.91 :-(
Motor tuning is set to 800 steps per for both x & Y
Looks like the error is constant and is same for both axis.
How do I correct for this error ?
