Hello Guest it is June 07, 2026, 03:57:28 AM
Author Topic: A stupid question, how to use the GOTO button?  (Read 18469 times)
« on: May 10, 2015, 12:33:50 AM »
I have read the manual and can't fine how to use the GOTO button.
I have gotten to the point, hit the GOTO button, touch a axis, type in location, what is next?
Offline dude1
  •  1,253 1,253
Re: A stupid question, how to use the GOTO button?
« Reply #1 on: May 10, 2015, 12:45:43 AM »
the goto button is useley for going to your work zero`s  x0. y0, z0, (a0 if its in there)work zero is what you are cutting, its what you set after homing the machine
« Reply #2 on: May 10, 2015, 12:51:22 AM »
No, there is a GOTO Home, and there is GOTO, you hit it it lights up, you touch a axis and add a location (say 1.5)
« Reply #3 on: May 10, 2015, 01:23:33 AM »
Dyslexic,  TOGO, sorry.
Offline dude1
  •  1,253 1,253
« Reply #4 on: May 10, 2015, 02:05:38 AM »
what screen set are you useing
Offline dude1
  •  1,253 1,253
« Reply #5 on: May 10, 2015, 02:08:19 AM »
togo is how far to go too machine zero
« Reply #6 on: May 10, 2015, 02:20:00 AM »
It is on the main screen
Offline dude1
  •  1,253 1,253
« Reply #7 on: May 10, 2015, 02:32:58 AM »
what is the name of the screen is it 1024.set
is it the buttion the arrow is pointing to
« Last Edit: May 10, 2015, 02:47:19 AM by daniellyall »
« Reply #8 on: May 10, 2015, 02:37:11 AM »
Sorry, it is main screen that comes up, it is what ever the Demo copy is, right from Mach3 D/L
« Reply #9 on: May 10, 2015, 04:40:14 AM »
ToGo, as has been said above , displays the distance left to go on the commanded move.
For example if you are at x0 y0 and you have NOT pressed the ToGo button, if you command a move to X10 Y10 then you will see the X and Y DRO count up to 10 as they approach the target location.
If however you have the ToGo button pressed then the DROs will start at 10 and count down to 0 as they move towards the commanded position, in other words they are showing the distance left to go as they aproach the commanded position.
