Hello Guest it is September 19, 2026, 11:01:52 AM
Author Topic: Can I "level" my work piece in software?  (Read 20700 times)
Re: Can I "level" my work piece in software?
« Reply #10 on: February 07, 2016, 02:23:40 PM »
Other controllers allow you to Probe the surface and create a matrix(table) for the controller to use to adjust the Z on the fly to match the surface profile of teh PCB or surface.
Offline rcaffin
  •  1,073 1,073
« Reply #11 on: February 07, 2016, 02:33:37 PM »
Well, yes, a bulge in the middle is actually 4th order: 2nd order in X and 2nd order in Y. So I modelled that and tested the Solver on it. Failure.
It was an interesting exercise all the same. The Solver was designed for business use, as far as I can see, which means it is focused mainly on linear models. It works quite well (very well) for those. I know that a full conjugate gradients package can handle 4th order easily enough because I have written such a package in the distant past, and used it very successfully.
Unfortunately the Mach Formulas feature will not handle the problem anyhow, as it is a very half-hearted implementation. It can handle G0 and G1 to a limited degree, but not G2/G3. Ah well, the real solution is to build a proper vacuum table - which is what my wife says I should have done in the first place.
cheers
Roger
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #12 on: February 07, 2016, 04:11:44 PM »
Well if you fortunate enough to get the go ahead from the wife then i would get right on it.
DazTheGas
Offline rcaffin
  •  1,073 1,073
« Reply #13 on: February 07, 2016, 04:23:21 PM »
Drawing and programming right now.
> Theres always time for a choccy biccy
Too Right!
Roger
